What Does Older Machines Include?
Dewey79
(@dewey79)
What is this forum topic for and what is considered "Older Machines"? The reason I ask is because a coworker's son received a Prusa REPRAP I3 3D printer as part of a course he's taking in school.
They are trying to learn more so I suggested that they look at this site mainly for general content to compare their issues. Now that they've added this tread is this where they can post questions?
Opublikowany : 10/04/2018 3:53 pm
Knickohr
(@knickohr)
Member Moderator
Re: What Does Older Machines Include?
This is maybe the answer :
https://en.wikipedia.org/wiki/Prusa_i3
Thomas
Opublikowany : 10/04/2018 4:11 pm
Jakub Dolezal
(@jakub-dolezal)
Member Admin
Hi David,
this section is dedicated to the printers developed by Josef Prusa prior to the Original Prusa i3 MK2. Have a look on the Wiki page posted by Thomas to see, which of the printer your coworker's son has or post the picture of it here 😉
Assembly manuals
/ Knowledge Base
Opublikowany : 11/04/2018 1:23 pm
I had a prusa mk1. 1.75mm filament. 5mm standard threaded bar for z axis. Red pcb heat bed and glass surface for heat bed. Direct drive extruder
Before this was the mk0. 3mm filament with geared extruder
Regards Joan
Opublikowany : 11/04/2018 3:40 pm
1 ludzie polubili
Dewey79
(@dewey79)
Yes, it looks to be a REPRAP "clone" maybe? There are several similar printers on Amazon. I just thought since it said PRUSA it was something from the beggining.
These are opensource so I guess they are just using the name.
Opublikowany : 12/04/2018 3:39 am
Ndv19
(@ndv19)
RE: What Does Older Machines Include?
@joantabb
My Name is Noel Vaughn.  I joined in hopes of trying to learn how to use a 3d printer.  I think I have what you are considering an older machine.  I have a Prusa I3? maybe don't know.  I has the fine Z axis threaded rods you spoke of.  It has an Audrino mega 25?? board on it.  I have downloaded Audrino 1.8.33 and am asking what do I do now.  I am not sure as to hook it up with the power on or what.  I have read at ReRap 1.4 but it doesn't tell me what to do.
Can you please guide me to where I need to go.
Thank You
Ndv19
Opublikowany : 19/04/2020 8:56 pm
3Delight
(@3delight)
Moderator Moderator
@Ndv19
That sounds like a clone (not a genuine Prusa printer).  You will need to look on places like reddit for help as this forum is for users of Original Prusa Research printers and software.  Try asking here: https://www.reddit.com/r/3Dprinting/ or here: https://reprap.org/forum/
Opublikowany : 23/06/2023 10:54 am
