Can I Use Distance with Marlin 2.X or not?
Josefaford
(@josefaford)
Just trying to find out if i should keep the box checked under printer settings for "Use relative E distance", I'm fairly new to 3D printing and it was checked automaticly when i created the profile for my Ender 5 Pro. But i see that it says unless your Firmware requires it to uncheck it. I have tried searching about Marlin to see if it requires it but I haven't found anything.
Opublikowany : 04/11/2022 6:38 am
RE: Can I Use Distance with Marlin 2.X or not?
You can use marlin 2.0, but it will request custom firmware installation.  I would stick with the stock.
Opublikowany : 04/11/2022 8:21 am
Robin
(@robin)
Unless you set your Ender 5 Pro to use absolute E values ( https://marlinfw.org/docs/gcode/M082.html ) you should keep that checked.
Normally relative E values are used, because using absolute values will accumulate errors over time and will result in less precise extrusion over time...
Opublikowany : 04/11/2022 12:35 pm
towlerg
(@towlerg)
I wonder why that is?
Opublikowany : 04/11/2022 5:21 pm
Robin
(@robin)
Posted by: @towlerg
Relative movement means telling the extruder how much to move every single time (extrude 2.4mm, extrude 1mm, extrude 3mm…)
Absolute movement means telling the extruder to extrude up to a position (extrude to 2.4mm, continue to 3.4, continue to 6.4…)
If you have a deviation it will be distributed evenly when using relative movement, but it will accumulate just as the number get bigger when using absolute positioning.
Opublikowany : 04/11/2022 7:44 pm
towlerg
(@towlerg)
I don't understand (very old brain) but thanks for trying.
Opublikowany : 05/11/2022 4:27 pm
Robin
(@robin)
@towlerg to put it differently: for relative movement you need on information less than for absolute: the current position and for absolute movement you need that to be exact. Walk 2 meters vs. walk from 1233 meters position to 1235 meters. That's only the same when you are at 1233m exactly and are sure about that.
Opublikowany : 05/11/2022 4:37 pm
towlerg
(@towlerg)
Thanks for the explanation.
Opublikowany : 07/11/2022 3:26 pm
