Wizard fails PrusaConnect
TroyBrock
(@troybrock)
Membre
installed my pi today, everything is successful until the prusalink wizard tries to connect to prusaconnect. It just sits at "set up printer" and doesn't go any farther. Prusalink says "encountered 4XX problems while communicating to connect". I can control the printer via prusalink on my local network so the wifi is working. I am logged into prusaconnect.
MK3s, Raspberry Pi Zero 2 W, firmware 3.10.1-4697
also when the printer starts up it doesn't not show the raspberry pi booting on the LCD, it just eventually pops up with the IP address.
Publié : 01/01/2022 5:18 pm
TroyBrock
(@troybrock)
Membre
RE: Wizard fails PrusaConnect
I reflashed and went through the wizard again. This time it worked. The only thing I changed was location from "#3" to "3". I'm not sure if that means special characters are not allowed or if there was some other issue.
Publié : 01/01/2022 7:46 pm
tomasvojtasek
(@tomasvojtasek)
Membre
Looks like we don't properly escape a printer's name when constructing the Connect's URL. Thanks for reporting, we gonna fix that
Publié : 05/01/2022 1:25 pm
Tojik a aimé
