Will the Raspberry Pi Zero 2 W also work?
Emery
(@emery-2)
as the title says. I would like to know if Prusa Link will also work with the Raspberry Pi Zero 2 W right now? It's almost impossible to get a Raspberry Pi Zero W in Germany right know.
Best whishes
Manuel
Posted : 23/12/2021 4:38 pm
Timo
 Timo
(@timo-2)
RE: Will the Raspberry Pi Zero 2 W also work?
I have just installed Prusa Link 0.6.0 on a Raspberry Pi Zero 2 W.
It's working just fine. Be sure to have patience on the first boot-up. It is installing and setting up some software.
When you see the IP address on the LCD you should be able to continue to the web interface.
Cheers,
Timo
I have no special talent. I am only passionately curious
Posted : 23/12/2021 10:00 pm
R3V3RS3R liked
Neolker
(@neolker)
It works well even when I just switched uSD card from the old version to 2 W with previous version of PrusaLink. I just noticed, that booting time is much faster with the new Zero.
Posted : 24/12/2021 12:22 am
Outsider
(@outsider)
As far as I know, an OS install on ANY Pi will work on any other Pi.
So yeah, it should work with no problems.
Posted : 24/12/2021 6:24 pm
Emery
(@emery-2)
Thank you for your answers. Just ordered the zero 2 w.
Posted : 24/12/2021 6:53 pm
burtronix
(@burtronix)
Now Pi Zero W is available at exorbitant prices & Pi Zero 2 W not at all.
Whatever you find to do with your hands, do with all your might!
Posted : 19/03/2022 7:35 pm
ezeackermann
(@ezeackermann)
Good afternoon,Are you connecting the RPI W2 through the internal port of the board or through USB? Does the Einsy board support the consumption of RPIw2?
Posted : 24/03/2022 5:20 pm
Tojik
(@tojik)
Member Moderator
It seems to be running just fine. Altho I have not stressed the PSU or board power wise. I've seen o throttling message in the log here and there but didn't pay atrention to it much.
Is there a spec sheet of maximum power for each power rail and an easy enough way to calculate how much of that is being used already?
Posted : 24/03/2022 6:32 pm
Outsider
(@outsider)
The Rpi W2 uses very little power
According to this source, it uses 120mA at 5V (600mW) under full load, which is nothing considering the PSU is 240W.
https://www.cnx-software.com/2021/12/09/raspberry-pi-zero-2-w-power-consumption/
Posted : 24/03/2022 8:10 pm
