Shell script to upload RTSP camera images to PrusaConnect Camera API
I just wanted to share my short script solution to upload to the PrusaConnect Camera API. This is worked out with the help of others' posts in this forum, so I thought other people might also find this helpful. It just requires that you have `ffmpeg`, `curl` and `bash` installed:
#!/usr/bin/env bash set -Eeuo pipefail shopt -s extdebug # shellcheck disable=SC2154 trap 'declare rc=$?; >&2 echo "Unexpected error (exit-code $rc) executing $BASH_COMMAND at ${BASH_SOURCE[0]} line $LINENO"; exit $rc' ERR main () { # Enable RTSP streaming for your UniFi Protect camera and paste the URL here. declare rtsp_stream="rtsps://10.10.10.10:7441/AbCdEfGh12345678?enableSrtp" declare token="YOUR_PRUSACONNECT_CAMERA_TOKEN_HERE" # Generate a new fingerprint with 'uuidgen'. declare fingerprint="YOUR_ARBITARY_PRUSACONNECT_CAMERA_FINGERPRINT_STRING_HERE" declare printer_uuid="YOUR_PRUSACONNECT_PRINTER_UUID_HERE" while sleep 30 do if ffmpeg \ -y \ -loglevel quiet \ -rtsp_transport udp \ -i "$rtsp_stream" \ -vframes 1 \ -q:v 1 \ -f image2pipe - \ | curl https://webcam.connect.prusa3d.com/c/snapshot \ -X PUT \ -s \ -H "Content-Type: image/jpg" \ -H "fingerprint: $fingerprint" \ -H "token: $token" \ --data-binary @- then printf "." else printf "?" sleep 30 fi done } main "$@"
Postato : 30/11/2023 5:20 pm
Marvzek hanno apprezzato
RE: Shell script to upload RTSP camera images to PrusaConnect Camera API
Thank you very much for your script. I am running it since a week and it works nicely. I am thinking about making a modification to turn on and off the for the shot.
Postato : 20/12/2023 6:45 am
