Shell script to upload RTSP camera images to PrusaConnect Camera API
I just wanted to share my short script solution to upload to the PrusaConnect Camera API. This is worked out with the help of others' posts in this forum, so I thought other people might also find this helpful. It just requires that you have `ffmpeg`, `curl` and `bash` installed:
#!/usr/bin/env bash
set -Eeuo pipefail
shopt -s extdebug
# shellcheck disable=SC2154
trap 'declare rc=$?;
>&2 echo "Unexpected error (exit-code $rc) executing $BASH_COMMAND at ${BASH_SOURCE[0]} line $LINENO";
exit $rc' ERR
main () {
# Enable RTSP streaming for your UniFi Protect camera and paste the URL here.
declare rtsp_stream="rtsps://10.10.10.10:7441/AbCdEfGh12345678?enableSrtp"
declare token="YOUR_PRUSACONNECT_CAMERA_TOKEN_HERE"
# Generate a new fingerprint with 'uuidgen'.
declare fingerprint="YOUR_ARBITARY_PRUSACONNECT_CAMERA_FINGERPRINT_STRING_HERE"
declare printer_uuid="YOUR_PRUSACONNECT_PRINTER_UUID_HERE"
while sleep 30
do
if ffmpeg \
-y \
-loglevel quiet \
-rtsp_transport udp \
-i "$rtsp_stream" \
-vframes 1 \
-q:v 1 \
-f image2pipe - \
| curl https://webcam.connect.prusa3d.com/c/snapshot \
-X PUT \
-s \
-H "Content-Type: image/jpg" \
-H "fingerprint: $fingerprint" \
-H "token: $token" \
--data-binary @-
then
printf "."
else
printf "?"
sleep 30
fi
done
main "$@"
Publié : 30/11/2023 5:20 pm
1 personnes ont aimé
RE: Shell script to upload RTSP camera images to PrusaConnect Camera API
Thank you very much for your script. I am running it since a week and it works nicely. I am thinking about making a modification to turn on and off the for the shot.
Publié : 20/12/2023 6:45 am
