How to set nozzle size/diameter in Prusa Connect?
Fabian
(@fabian-5)
Hi all,
I successfully installed firmware 5.1 on my Mini+ and hooked it up to Prusa Connect, which was pretty easy so far.
I run my Mini+ with a .6 nozzle, which is correctly set up in Prusa Slicer. But when it comes to Prusa Connect, the web interface lists a .4 nozzle. For that reason I get a notification each time I try to start a print via web interface and have to confirm the correct nozzle at my printer physically.
How can I set up the correct nozzle size in Prusa Connect?
Thanks!
Cheers, Fabian
Napsal : 25/11/2023 8:07 pm
Fabian
(@fabian-5)
RE: How to set nozzle size/diameter in Prusa Connect?
Got it myself. Can be set up in the printer menu under "hardware"
Napsal : 26/11/2023 5:25 pm
Tojik se líbí
Tojik
(@tojik)
Member Moderator
Sorry, i totally missed this one :/
Napsal : 04/12/2023 8:31 pm
