Camera on PrusaLink but not PrusaConnect
mpeill
(@mpeill)
I'm probably looking for an idiot's guide here, so please bear with me.
I've installed a RPi zero 2W into my Mk3s, and set up both PrusaLink and PrusaConnect. Both work great.
I've then installed a usb camera (endoscope) into the RPi, and it works great in PrusaLink where I see images every 10 seconds.
However, in PrusaConnect there is no resulting camera present. Maybe I need to add this in software somehow, but I'm at a loss as to how. I can't scan the barcode offered in PrusaConnect since it's not a phone camera so no scanning app. There's talk of an API, but I've no idea what to do with that !?!?
Help if possible please.....
Opublikowany : 20/11/2023 12:39 pm
Tojik
(@tojik)
Member Moderator
RE: Camera on PrusaLink but not PrusaConnect
Hi, try going to the local PrusaLink web interface, into the cameras tab. You should see a switch near the top right of the camera list item, click that so it looks switched on. That should enable the camera to send pictures to connect. Hope that helps.
Opublikowany : 20/11/2023 4:42 pm
mpeill
(@mpeill)
Oh, THAT button...... well that was easy. I was expecting some sort of complicated c++ code.
It's always the easy things that I miss. Thanks so much, working great in PrusaConnect as well now. Top marks to you.
Opublikowany : 21/11/2023 9:19 am
1 ludzie polubili
Patrick.b
(@patrick-b)
Hi Tojik
any idea for update prusalink with the mk4 !!! 😭 😭 😭  no camera, no control , no settings..
Opublikowany : 24/11/2023 8:57 am
Tojik
(@tojik)
Member Moderator
No idea, not working on the mk4. The printer itself does not have the throughput to handle camera data while printing and doing everything else. The control tab must have ended up in the unimportant pile.
Please do not hijack threads
Opublikowany : 24/11/2023 9:12 am
