Página 2 / 2
Anterior
RE: Results input shaper
I think it depends a lot on the model you print. My experience is that IS does not work well with big top surfaces, it is just not smooth at all
Respondido : 19/08/2023 1:49 pm
Those ripples on your X axis are way too excessive. Try to swap the pulleys between the axes and see if the ripples move to the other axis. If yes, then you have a faulty pulley. Replacing it should fix the ripples.
I printed an IS Test too, but there is no ideal Frequency to choose from. I printed this with 110 mm/s.
Y-axis
X-axis
Simon 🙂
Respondido : 06/11/2023 8:46 pm
1 les gusta
Página 2 / 2
Anterior
