5.0.0-alpha2 Firmware for Original Prusa MK4
Same Old Shane
(@same-old-shane)
Mitglied Admin
Hello all,
We are happy to announce the latest version of our input shaping firmware for the MK4, 5.0.0 - alpha 2. Please note that this is still a alpha version, so if you encounter a bug, please report it via the github ticketing system so the developers can see it .
Summary
  • Optimization and code refactoring
  • Fixing filament change procedure
  • Known bugs
Firmware release 5.0.0-alpha2 for the Original Prusa MK4 is focused on bug fixes, code refactoring and optimization.
Polishing the code base was our priority for this release. We have been able to eliminate system crashes (BSODs) in all known edge cases. Moreover, we have been able to restructure and streamline the code and even cut some unnecessary or redundant computations. These improvements are necessary for further development.
Our most recent implementation of Pressure Advance caused issues during the filament change procedure. This has been solved by disabling PA during the unloading of the filament.
Known bugs
There are several bugs in the current alpha we are still working on.
  • False filament runout is sometimes triggered without an obvious physical cause.
  • Skipped layers can occur randomly.
  • Random layer shift on X and Y axes.
  • A boot loop can occur. Restarting the printer solves it (use the main switch, not the reset button).
  • Power panic and networking functions can cause errors.
Douwnload;
github.com/prusa3d/Prusa-Firmware-Buddy/releases/tag/v5.0.0-alpha2
Shane (AKA FromPrusa)
Veröffentlicht : 22/06/2023 8:53 am
Yasar
(@yasar)
Hi is the silicone sock option built in? Or must install 4.6.4 !?
Veröffentlicht : 22/06/2023 2:08 pm
jseyfert3
(@jseyfert3)
RE: 5.0.0-alpha2 Firmware for Original Prusa MK4
https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-assembly-and-first-prints-troubleshooting/heaters-test-fails-if-silicone-sock-is-installed/#post-661125
Posted by: @atilla
Veröffentlicht : 22/06/2023 3:45 pm
Seanhs
(@seanhs)
Mitglied
Is input shaping available for 0.6mm nozzles as well? Or is it just 0.4mm?  Didn't mention it on the github page.  Thanks!
Veröffentlicht : 23/06/2023 3:12 pm
Walter Layher
(@walter-layher)
So far there is only an IS profile for 0.4 mm available in PrusaSlicer.
Veröffentlicht : 23/06/2023 4:17 pm
Tobias Stanzel
(@tobias-stanzel)
Input shaping also for 0.6 nozzles would be awesome, even faster prints! I am sure it will come.
Veröffentlicht : 24/06/2023 11:02 am
Yasar
(@yasar)
Not usable for me
the problem that occurs more frequently
- Skipped levels can occur randomly (the print stops during print)
- and the print doesnt start ... It doesnt start to heat
Go back to 4.6.4 🙁
Veröffentlicht : 24/06/2023 2:40 pm
MarcWinNJ
(@marcwinnj)
Is the WIFI disconnect issue fixed in this release.
Veröffentlicht : 27/06/2023 1:38 pm
Protoncek
(@protoncek-2)
Hm.. .i'm experienced rather contrary: my wifi is solid, while ethernet is dropping connection...
But, both connections are painfully slow when transferring files. Will this slow speed be in any way improved?
Veröffentlicht : 30/07/2023 12:25 pm
