12 minute Bonkers Benchy made me smile.
Stránka 2 / 2
Koegmaster
(@koegmaster)
Hi All,
for me the 12 minute Benchy gets heavy layer shifts (see pictures). Am I the only one with this problem?
I do have my MK4 in the original enclosure though, maybe the Filament guide is a problem here?
Or do you think my belts are somehow loose? With the rest of my prints like e.g. the 27 minutes Benchy I do not have any problems though.
This post was modified před 3 years by Koegmaster
Napsal : 09/06/2023 2:18 pm
carlmmii
(@carlmmii)
RE: 12 minute Bonkers Benchy made me smile.
Check your Y-axis (bed) belt tension and make sure there's no debris on the rails that might prevent smooth motion. Also, check that your nozzle is secured with the thumbscrews tight.
Something is causing your Y-axis to shift, either from a skip in the belt, or an obstruction in bed movement either from the track area or from nozzle collision with the part.
Napsal : 10/06/2023 7:37 am
Koegmaster
(@koegmaster)
Posted by: @carlmmii
Hi thanks for your answer, I wasn't able to test the last week but I just did another test print and the belt was clearly skipping, so I tighten it a little and now everything looks good!
Thanks
Napsal : 16/06/2023 2:38 pm
1 lidem se líbí
Neolker
(@neolker)
Still looks better than mine 🙂
Posted by: @koegmaster
Hi All,
Napsal : 27/06/2023 9:55 am
Rainer
(@rainer-2)
Unbelievable, my MK4 inspires me more and more.
Napsal : 02/07/2023 1:33 pm
adcurtin
(@adcurtin)
https://github.com/prusa3d/Prusa-Firmware-Buddy/releases/tag/v5.0.0-alpha1
gcode files are here, since it took me longer than it should have to find them
Napsal : 25/07/2023 6:07 am
diablo2112
(@diablo2112)
After 5 years with the Mk3 and Mk3s, the Mk4 just blows me away.  12 minutes.  Amazing.
This post was modified před 3 years by diablo2112
Napsal : 26/07/2023 4:36 pm
Stránka 2 / 2
