Under-extrusion or gaps at seams with input shaper settings and 5.x firmware
Seite 1 / 3
24 Karat Karl Marx Champagne
(@24-karat-karl-marx-champagne)
I have a mini+ but I think this issue might be on all Prusa printers with the recent input shaper enabled. Basically, there's ugly gaps at the seams. There seems to be other reports of the same issue but they don't have much traction:
The problem exists when I use a PrusaSlicer printer profile with the input shaper enabled. I'm using PrusaSlicer 2.7.0 and firmware 5.1.0. I'm using "0.20mm STRUCTURAL" printer presets.
If I use a PrusaSlicer printer profile WITHOUT input shaper enabled, the problem is much less. Perhaps still not as good as firmware 4.x but I'm not sure about that 100%.
Veröffentlicht : 13/12/2023 12:04 pm
RE: Under-extrusion or gaps at seams with input shaper settings and 5.x firmware
Is this the right place to report it? Or would it be better on Github?
If you want to report an issue the github is the correct (only) place to do so.  There are githubs for the slicer and also for the printers.  If you think its a firmware issue then it needs to go into the Buddy one as that is what the Mini uses.  The devs there will move it anyway if they think it isn't in the right repo.
Veröffentlicht : 13/12/2023 1:27 pm
mark
 mark
(@mark)
What filament are you using?
You might want to adjust the extruder tension screw. I have found that the faster speed of the input shaper requires more tension to not slip and underextrude.
Regards,
Mark
Veröffentlicht : 13/12/2023 3:55 pm
Kroun1
(@kroun1)
Mitglied
I have the same issue. The below pictures are with IS SPEED profile. But even when I switched to non IS, it seems to be not as good as it used to be with 4.4.1 FW.
Veröffentlicht : 13/12/2023 9:10 pm
OK thanks. I'm just not sure if it's a printer or slicer issue, they both had to be updated to enable the Input Shaper options...
Veröffentlicht : 15/12/2023 12:04 pm
Posted by: @mark-3
Regards,
Mark
I'm using Overture Matte. Do you mean what is described here? In PrusaSlicer I see no change in Flow or speed at the seam though...
Veröffentlicht : 15/12/2023 12:10 pm
I made a better photo here:
Veröffentlicht : 15/12/2023 12:16 pm
I created a Github issue here: https://github.com/prusa3d/PrusaSlicer/issues/11914
Veröffentlicht : 15/12/2023 12:33 pm
mark
 mark
(@mark)
Posted by: @24-karat-karl-marx-champagne
Posted by: @mark-3
Regards,
Mark
Yes that is what I was talking about, the extruder adjustment.
I have no experience with Overture Matte.
Regards,
Mark
Veröffentlicht : 15/12/2023 11:41 pm
Scott Bierly
(@scott-bierly)
I will add a slightly different potential issue. I live in the particular hell of almost exclusively printing 85A TPE, currently on the Mini. Just when I thought I'd found all the right hoops to jump through while patting my head, I've spent the last week iterating on narrowing down massive underextrusion which none of my known fixes cure. This happened to begin right after I upgraded to the new firmware and input shaper profiles. I assumed everything else, but to no avail. I'll next try reverting back the software/firmware and report back, but sharing now in case others have the same issue.
Veröffentlicht : 18/12/2023 9:01 pm
AEC
 AEC
(@aec)
Mitglied
I got the same issue, tried tweaking the retraction and speeds without any luck. It was unfortunately so bad that I've had to downgrade the printer to be able to get reliable output from it.
I'll try adjusting the extruder tension screw, sounds plausible it could cause it if it doesn't grip the filament properly.
Veröffentlicht : 18/12/2023 9:52 pm
Spin360
(@spin360)
Posted by: @aec
Which firmware are you using now?
Veröffentlicht : 21/12/2023 11:25 am
Tysonsw
(@tysonsw)
I have the same issue on my Mini+ with the latest PrusaSlicer build, and the latest Firmware.
Using add:north PLA filament and PETG.
I almost had no visible seams when using the non-IS profiles before the upgrades.
Printer: Original Prusa Mini+
Nozzles: E3D 0.25, E3D Nozzle X 0.4 , E3D 0.4, Bondtech 0.6 CHL
Printables: Tysonsw
Mastodon: [email protected]
Veröffentlicht : 03/01/2024 9:13 am
MIWM
 MIWM
(@miwm)
Im having the same issues, Ive been on Prusa chat no less than 3 times trying to figure this out..
At first I was having what looked like perferation from the seams not fully filling in. I dissassembled the extruder and cleaned, dissasembled the hotend and cleaned/ replaced the nozzle.. my prints are still so bad Im considering dowloading an older version of the firmware since yhere seems to be no way to turn input shaping off.
Veröffentlicht : 03/01/2024 6:14 pm
PrintyKitty
(@printykitty)
I too, have since downgraded to the non-IS option. The speed increases in IS was not worth the headache of having 3D parts be much worse in quality than before. I have noticed substantial gaps in the perimeter walls in spite of making many adjustments to my temperature, perimeter settings, retraction settings, Z-height, making filament swaps. It's like I have a broken printer when IS is enabled...
Veröffentlicht : 05/01/2024 5:53 pm
Lynn
 Lynn
(@lynn)
I might be missing the main goal of this thread, but looking at your pics, I immediately think  of improper linear advance settings (pressure advance for Klipper).  The appearance at the seams is the dead giveaway.  On my Voron 2.4 when I went to a higher volumetric flow rates (which happens with the IS profiles), I got prints that looked just like the pics in this thread. Since then I have experienced the same issue on my MK3 when I started pushing the flow rate. I  agree that the presets being provided by Prusa should not have this problem, but if it is a linear advance issue you should be able to fix it calibrating the linear advance settings. The appearance at the seams is the dead giveaway.
If you decide to look at linear advance, I recommend
https://ellis3dp.com/Print-Tuning-Guide/articles/index_pressure_advance.html
Diese r Beitrag wurde geändert Vor 2 years von Lynn
Veröffentlicht : 05/01/2024 9:15 pm
mark
 mark
(@mark)
Prusa does not yet provide a linear advance calibration for the Mini, but someone did:
https://www.printables.com/model/53359-prusa-mini-linear-advance
There are a couple remixes for PETG also.
I am going to try it and see what happens.
Regards,
Mark
Veröffentlicht : 05/01/2024 10:29 pm
MIWM
 MIWM
(@miwm)
Thank You! Youre right, I also initially thought it was a it was like moving to fast for it to fill in since first layers print pefect and slower. Ive been messing with retraction since I chatted with tech support but in the corners of the green and blue boxes you can see adhesion issues See gaps in the corners
When you messaged me earlier I started looking into it more and found in the prusa document where it talks about  flow rate by adjusting the extrusion multiplier, (1=100% .95= 95%) so I reset all my retraction tuning 🙃 , and ive been fine tuning ..
I started a more basic retraction test to save time and material it was still having little gaps around edges so I used this to tune.
I think im at a good spot a 1.12, there is still a ever so small gap on the corner but its real small. If anyone knows how to adjust that corner speed just a teeny bit slower I think that may solve it..
Heres a pick of it with extrusion multiplier set at 1.12
For refrence this is ESun Pla+ 112⁰
Hope the pics help.
Any other tuning advice is appreatiated too.
Veröffentlicht : 06/01/2024 12:18 am
mark
 mark
(@mark)
Posted by: @mark-3
Regards,
Mark
For Prusament PETG, the default k factor for a .4 nozzle is 0.4. After printing the test, 0.48 looked a little better to me, so about 20% higher. I will try that. I noticed that the presets for TPU do not include pressure advance.
I used a little too much of my magic glue stick, so the filament is peeling off in a few places, but that doesn't affect the results.
Regards,
Mark
Diese r Beitrag wurde geändert Vor 2 years von mark
Veröffentlicht : 06/01/2024 1:38 am
Seite 1 / 3
