Translating from non input shaper to input shaper
Okay so after LOTS of trial and error, I FINALLY got my machine to print Benchy's right, but I did it without IS to eliminate speed as a variable. So, two part question; now that I have a filament profile for Overture PETG that works correctly WITHOUT Input Shaper, if I bring it over to PrusaSlicer with the printer profile set to Mini+ WITH Input Shaper, will it translate? And if that's an option, how can I save that filament profile to my computer and then add it to the printer profile with Input Shaper?
Sorry in advance if that's a stupid series of questions, I just couldn't find anything with the search function and am finally excited about using this machine for the first time since I got it!
RE: Translating from non input shaper to input shaper
I don't know how to answer your question, but would you mind sharing your profile for the Overture PETG. I have been messing with it the last couple of days without much success.
For what it's worth, I did not have good luck with Overture PETG on the Mini. I have had good results with Hatchbox PETG, including input shaper.
Regards,
Mark
Absolutely! Now aside of screenshotting every screen, can someone tell me if there's a way to send a file with all my settings that are working? Sorry, I'm dumb with this stuff
Projects you save in .3mf format have all the settings. People here often ask you to save as such so they can try to duplicate a problem.
Regards,
Mark
Okay nothing is showing up as a .3mf format but my computer keeps trying to recognize PrusaSlicer files as PDF's for some reason so I think that's what you're looking for. I also found a way to save the configuration from Slicer, and it just opens in a notepad but for you guys who know what you're doing I bet it makes sense to you. It's basically every setting spelled out line by line. Hope that helps.
Here's the Benchy from my flashdrive with all the Overture settings that came out about as clean as I could hope for.
