Translating from non input shaper to input shaper
Kyle Kerby
(@kyle-kerby)
Okay so after LOTS of trial and error, I FINALLY got my machine to print Benchy's right, but I did it without IS to eliminate speed as a variable. So, two part question; now that I have a filament profile for Overture PETG that works correctly WITHOUT Input Shaper, if I bring it over to PrusaSlicer with the printer profile set to Mini+ WITH Input Shaper, will it translate? And if that's an option, how can I save that filament profile to my computer and then add it to the printer profile with Input Shaper?
Sorry in advance if that's a stupid series of questions, I just couldn't find anything with the search function and am finally excited about using this machine for the first time since I got it!
Opublikowany : 29/08/2024 4:23 am
Alabuk
(@alabuk)
RE: Translating from non input shaper to input shaper
I don't know how to answer your question, but would you mind sharing your profile for the Overture PETG.  I have been messing with it the last couple of days without much success.
Opublikowany : 30/08/2024 9:34 pm
1 ludzie polubili
mark
 mark
(@mark)
For what it's worth, I did not have good luck with Overture PETG on the Mini. I have had good results with Hatchbox PETG, including input shaper.
Regards,
Mark
Opublikowany : 31/08/2024 5:57 am
1 ludzie polubili
Kyle Kerby
(@kyle-kerby)
Absolutely! Now aside of screenshotting every screen, can someone tell me if there's a way to send a file with all my settings that are working? Sorry, I'm dumb with this stuff
Opublikowany : 31/08/2024 10:46 pm
mark
 mark
(@mark)
Posted by: @kyle-kerby
Projects you save in .3mf format have all the settings. People here often ask you to save as such so they can try to duplicate a problem.
Regards,
Mark
Opublikowany : 01/09/2024 1:34 am
1 ludzie polubili
Kyle Kerby
(@kyle-kerby)
Okay nothing is showing up as a .3mf format but my computer keeps trying to recognize PrusaSlicer files as PDF's for some reason so I think that's what you're looking for. I also found a way to save the configuration from Slicer, and it just opens in a notepad but for you guys who know what you're doing I bet it makes sense to you. It's basically every setting spelled out line by line. Hope that helps.
Opublikowany : 02/09/2024 3:28 pm
Kyle Kerby
(@kyle-kerby)
Here's the Benchy from my flashdrive with all the Overture settings that came out about as clean as I could hope for.
Opublikowany : 02/09/2024 3:29 pm
