Prusaslicer Input Shaper makes omissions both lower and upper layers
Prusa Mini+, PrusaSlicer 2.7.1, Firmware 5.1.2
Test print PLA 3cm x 3cm x 1mm centered 13mm hole. Lots of holes on the edge with input shaper. Picture on the left
Significantly better without input shaper. Middle image
Best with Ocra. Picture right.
I have tried all possible settings with Input shaper, the result is always equally bad.
I hope that there are still improvements to be made in the Input Shaper.
Or does anyone have a solution to the problem?
Publié : 20/01/2024 1:36 pm
RE: Prusaslicer Input Shaper makes omissions both lower and upper layers
Calibrate your flow rate and adjust the extruder tension. Maybe also calibrate the k factor.
https://help.prusa3d.com/tag/mini/calibration_199#articles
Regards,
Mark
Publié : 20/01/2024 8:21 pm
Topic starter
answered:
Thank you Mark for your support.
I have now followed your adjustments.
Most of the success came from increasing the extrusion factor.
Publié : 22/01/2024 11:30 am
