Is this firmware compatible with a Revo Mini hot end?
kevman
(@kevman)
Curious if I can use this firmware with my modified printer.
Postato : 19/09/2023 12:20 am
MetroKitten
(@metrokitten)
Utenti
RE: Is this firmware compatible with a Revo Mini hot end?
Loaded it on mine with a revo mini, did the 17 miniute benchy and was successful. Doing some gridfinity boxes as a another test now and seems to be working out really well.
Postato : 19/09/2023 2:51 am
Clares
(@clares)
Utenti
You didn't change anything even on stock firmware after installing Revo, it's made to be a drop-in replacement, don't worry about compatibility c:
So excited to see this update this early
Postato : 19/09/2023 4:22 am
Sugarlumpz
(@sugarlumpz)
Wouldn't the input shaper profile need to change if the hotend weight changes? Wouldn't a Mini with mods affecting weight, movement, rigidity (aka the Prusa Mini Base) change its standard resonance that input shaper compensates for?
Postato : 19/09/2023 1:38 pm
Neolker
(@neolker)
Utenti
Yes, some of ppl with Revo confirmed that it works pretty well, even with 0.6 mm nozzle with 0.4 mm profile 😋 but it still in Alpha, so we can still expected some fine tuning.
Postato : 19/09/2023 2:38 pm
TheBavarianModelMaker
(@thebavarianmodelmaker)
Utenti
I tested it on my MINI+ with Revo Hotend, and it works excellent for models I sliced myself (0.4mm Nozzle)
But The provided 16-minute bonkers benchy looks very ugly. A benchy following the speedboot rules looks almost perfect and took just 46 minutes to print.
Postato : 20/09/2023 7:16 am
