Error while printing : Precise data access
Grininventor
(@grininventor)
I got this error mid print : Precise Data Access, followed by a lot of characters. I can put an image of someone explains me how to do it. Here is a link to the image
Does anyone knows what this is ?
Opublikowany : 10/10/2023 10:35 pm
Hello
(@hello)
RE: Error while printing : Precise data access
At the top when you go to post it says add media click that to add.picture
Opublikowany : 10/10/2023 11:13 pm
Grininventor
(@grininventor)
Thanks for the info.
Here is the picture :
I also have the crash dump file, but I don't know if it can help here on the forum.
Opublikowany : 10/10/2023 11:27 pm
Hello
(@hello)
Posted by: @grininventor
Yes add the crash dump that will help looks like an error getting to prusa connect carnt be sure until I get crash dump
Opublikowany : 11/10/2023 3:25 am
Grininventor
(@grininventor)
Here is a link to download my crash dump because the forum doesn't allow me to uplaod .bin files.
Edited by Joan,
If you Zip compress the zip file, you can load it into the forum
dump_buddy
Regards Joan
Opublikowany : 11/10/2023 7:16 am
Hello
(@hello)
Edited by Joan,
dump_buddy
Regards Joan
So the dump is corrupt it took a while but I've debuged some of it was it when you were printing mgsafe clamp
Opublikowany : 11/10/2023 9:03 am
Hello
(@hello)
That's the last known error I did see a 401 error with connect but that was on boot oh and the random characters are because it's corrupt
Starts below
not enough space for format expansion (Please submit full bug report
GCDE/home/admin/workspace/RELEASE-input_shaper_mini-alpha1/lib/Middlewares/Third_Party/FreeRTOS/Source/portable/GCC/ARM_CM4F/port.c�freertos configASSERT�/home/admin/workspace/RELEASE-input_shaper_mini-alpha1/lib/Middlewares/Third_Party/FreeRTOS/Source/event_groups.c�/home/admin/workspace/RELEASE-input_shaper_mini-alpha1/lib/Middlewares/Third_Party/FreeRTOS/Source/queue.c�/home/admin/workspace/RELEASE-input_shaper_mini-alpha1/lib/Middlewares/Third_Party/FreeRTOS/Source/tasks.c�IDLE�TmrQ�Tmr Svc�/home/admin/workspace/RELEASE-input_shaper_mini-alpha1/lib/Middlewares/Third_Party/FreeRTOS/Source/timers.c���St19_Sp_make_shared_tag�ð•@”not enough space for format expansion (Please submit full bug report N12_GLOBAL__N_121system_error_categoryE�*N12_GLOB
Opublikowany : 11/10/2023 9:15 am
Hello
(@hello)
Try do a print without input shaper if it works try reflash the firmware that's all I can think of it's throwing a few errors anyone else got ideas
Opublikowany : 11/10/2023 9:16 am
Grininventor
(@grininventor)
Yes it's when I was printing the Magsafe Clamp, I cleaned my usb drive, re-flashed the firmware and re-configured PrusaConnect. Now everything works correctly, except PrusaLink, but that's the case for almost everyone with the beta firmware I think.
Thanks for the help 😜
(how should I open a .bin file like the crash dump to see what the error is ?)
Opublikowany : 11/10/2023 9:34 am
Grininventor
(@grininventor)
And also, why can't I edit any of my posts ?
Opublikowany : 11/10/2023 9:46 am
There is a very short window if opportunity to edit. This is a spam reduction issue.
Opublikowany : 11/10/2023 11:25 am
1 ludzie polubili
Hello
(@hello)
Normally you can rename the file to txt file but yours was corrupt forsome reason
Opublikowany : 11/10/2023 6:54 pm
