Benchy B/GCODE for Prusa Mini with IS...
rbid
 rbid
(@rbid)
When the Prusa Mini was shipped, it came with a bunch of example gcode files, one of them was the famous benchy, which was optimized for showing the MINI capabilities.
It will be nice if Prusa will publish a optimized-for-the-mini-with-input-shaping benchy b/gcode, in this way you can show the capabilities/quality of the new feature.
Shut!
Publié : 21/12/2023 8:16 am
stereoprologic
(@stereoprologic)
Membre
RE: Benchy B/GCODE for Prusa Mini with IS...
There's two .gcode files on the 5.1.0 alpha1 release: https://github.com/prusa3d/Prusa-Firmware-Buddy/releases/tag/v5.1.0-alpha1
Publié : 25/12/2023 9:08 am
savlik.zdenek
(@savlik-zdenek)
Membre
I can't find the right settings of slicer to get same print time as in gcode, I tried increase speed limits in default IS speed profile and I'm at 37 minutes :/ Does anybody know top speed limits settings of machine, I don't wanna break it 🙂
Publié : 01/01/2024 7:57 pm
muhendees
(@muhendees)
Open that gcode file with text editor and scroll to the end. Usually they include configuration at the end
I just checked Bonker's benchy file and see them.
Sample:
; prusaslicer_config = begin
; arc_fitting = disabled
; arc_fitting_tolerance = 5%
; autoemit_temperature_commands = 1
; avoid_crossing_curled_overhangs = 0
; avoid_crossing_perimeters = 0
; avoid_crossing_perimeters_max_detour = 10
Publié : 02/01/2024 6:07 am
1 personnes ont aimé
muhendees
(@muhendees)
I played around PrusaSlicer a bit and found out you can actually import settings from GCODe file as a profile:
Open PrusaSlicer, Go to File -> Import -> Import config or press Ctrl+L(on windows) and select GCODE you want to use
Publié : 02/01/2024 10:11 am
rbid
 rbid
(@rbid)
Yes, this can be very useful if you have a GCODE or /BGCODE file.
But if the GCODE/BGCODE file were manually edited to add some special functionality, then, these will not be imported.
Publié : 14/03/2024 3:01 pm
Lucas Jaeger
(@lucas-jaeger)
Ok so call me crazy, but I have printed with my Prusa mini at about 500mm/s with 35K Acceleration and it still works perfectly fine after over fifty hours since. Don't have to worry. I also managed to print a speed boat race legal 8 min benchy on it, with only mod is a am holding a fan next to it to keep it cool.
Publié : 20/03/2024 5:01 am
