Uneven lines in my Slugs - Photos and 3mf file
Steverd
(@steverd)
I can not figure out how to get a better articulating slug on my minis.
See the slug photos for the uneven lines on the sides and ugly bottoms.
I also just printed a cube on this same printer to see if it showed anything way off.
I have tried many different settings and can not find the perfect ones.
Here is the 3mf: SlugV1.1_wBrims 4 Inches TEST 2022b
Is anyone up to the challenge? Thank you so much.
Postato : 19/01/2022 3:25 am
Swiss_Cheese
(@swiss_cheese)
RE: Uneven lines in my Slugs - Photos and 3mf file
Steve it's not the printer its the way you sliced it.
here's a hint: look at your extrusion widths.
Good Luck
Swiss_Cheese
The Filament Whisperer
Postato : 19/01/2022 4:46 am
Steverd
(@steverd)
I almost forgot I posted this a week ago.
Swiss_Cheese - I REALLY appreciate all of your help - I feel like I should be paying you 🙂
Here are my Extrusion widths from the file, they are all set to default as far as I can tell.
Is it the External Perimeter that is the problem? As a beginner I am pretty lost .
Postato : 26/01/2022 8:36 pm
Steverd
(@steverd)
This issue still has not been solved - Can anyone give more suggestions?
Swiss_Chess mentioned: here's a hint: look at your extrusion widths.
BUT that didn't help me - I more detailed directions 🙂
Thank you
Postato : 20/04/2022 10:08 pm
