[Résolu] Uneven Layer problems
Till3D
(@till3d)
I recently encountered this problem: The layers are printed in this "pattern". Does anyone know what might be causing this?
Printed on a mini+ with Prusament PETG.
Publié : 19/06/2022 2:55 pm
Robin
(@robin)
Looks like the z-offset is a bit to much (low). Run first layer calibration and reduce the offset a bit or use live z-adjust to do the same when starting the next print.
Publié : 24/06/2022 1:10 pm
Till3D
(@till3d)
Solved it
I solved it. The issue was a clogged nozzle.
Publié : 03/11/2022 6:38 am
