trying to print a cylinder 95% infill with 3d honeycomb, print keeps failing
Red Towel
(@red-towel)
Hi all ,
so this is what im trying to print
with these settings
and this is what im getting
it seems that the nozzle is contacting the cylinder and drags the print off adhesion and then sticks the whole thing to the nozzle.
thats where im at so far after playing with some settings.
any help would be much appreciated
PS
my first post , please tell me if im in the wrong place
Napsal : 04/09/2021 11:04 pm
Please show us your first layer Z calibration print.
Napsal : 04/09/2021 11:33 pm
Red Towel
(@red-towel)
first layer z cal
Napsal : 05/09/2021 12:03 am
sylviatrilling
(@sylviatrilling)
First Layer Calibration
Your print is failing because your z-offset from your first layer calibration is not correct. It looks like your nozzle is too low. The rectangle should be smooth and uniform. Take a look at https://help.prusa3d.com/en/article/first-layer-calibration_112364
Mk3S+,SL1S
Napsal : 05/09/2021 1:42 am
Red Towel
(@red-towel)
thanks
thanks . ill check it out right now .
Napsal : 05/09/2021 1:47 am
Thank you.
The nozzle clipping the print is often due to poor adhesion, one end lifts off the bed into the path of danger.
Your first layer Z setting is too low, too squished.
At the end of the calibration you are aiming to print a single layer *sheet*. It should be possible to peel it off in one and fold it without the threads seperating. If it breaks into lines it is too high, not squished enough. If it is a single sheet but with wavy lines or drag marks on it you are too low.
I suspect you may have gone too low in trying to overcome prior poor adhesion.  From the groups of glitches in your trace I recognise the effects of fingerprints on the print sheet...
Alcohol is OK for maintaining cleanliness but every now and then a more rigorous degreasing is required.
Clean the sheet with dishwashing detergent (Dawn/Fairy) and plenty of HOT water, rinse well and dry with a fresh paper towel. Handle by the edges only.
Why do you need such a dense print with such fine infill?
If you are trying for strength I would suggest 0.2mm layers with Cubic infill at 20% and if you need extra strength select 4 or 5 perimeters.
Napsal : 05/09/2021 1:55 am
Red Towel
(@red-towel)
update
ok so i adjusted to what i think is more consistent with good first layer calibration. however im still getting the same result .
as the print begins to start the honey comb 3d infill , it seems to fill and squish , causing the filament to pile up and become deeper . The nozzle then drags the filament along with the rest of print off adhesion and drags it around as it tries to keep printing.
for clarity and this is something i should have mentioned before, IM getting good prints with other infills, ( rectilinear ) but honey comb 3d is  completely not working right now .
could it be that it doesnt like the 90 percent infill ?
Napsal : 05/09/2021 3:06 am
Red Towel
(@red-towel)
thanks for that . ill give it a go
the density is to increase weight .
ill try adjusting my layer calibration again  tomorrow.
Napsal : 05/09/2021 3:09 am
3mf and photo
Can you post another image of the new calibration square and upload the 3MF file zipped?
Posted by: @red-towel
Napsal : 05/09/2021 10:48 am
BogdanH
(@bogdanh)
the density is to increase weight ...
-if that's the only reason, then such high density infill is waste of filament. You should try to insert some (metal) weight during printing.
See example here or here.
[Mini+] [MK3S+BEAR]
Napsal : 05/09/2021 11:08 am
Red Towel
(@red-towel)
thanks for that, ill take it into consideration
thats a great idea !  however , id like to see if i can acheive certain weights with just filament at the moment.
Napsal : 05/09/2021 7:55 pm
Red Towel
(@red-towel)
heres the first layer cal i tried this time and the file of the print
cylinder experiment
Napsal : 05/09/2021 9:47 pm
You might change your top layer infill to Concentric and Cubic fill for the rest will print faster with less shaking.
Your first layer looks much better but the print sheet needs cleaning.
Napsal : 06/09/2021 9:57 am
Red Towel
(@red-towel)
ok good to hear
i just gave the bed a wash in dish soap and water.  could it be time for acetone  ?
Napsal : 06/09/2021 9:19 pm
Acetone
If you try it, only use a quick spray and wipe.  Do not alllow it to stand.
Napsal : 06/09/2021 9:24 pm
Red Towel
(@red-towel)
Duly Noted.
Thanks . ill give that a try when i get acetone.
Napsal : 06/09/2021 11:12 pm
Red Towel
(@red-towel)
update . no more breaking . upped my bottom layers. still messing up the 3d honey comb
so im getting more or less the same result except now its not ripping the print off the bed.  its still sloshing the 3d honeycomb around.
could it be that my nozzle needs to be smaller for finer detail ?
Napsal : 09/09/2021 4:21 am
No
It is not the nozzle.  Keep adjusting the Z height and keep the bed clean.  You will eventually get the right Z height.  You could also try a quick spray of hair spray on the bed - Aquanet is best.
Napsal : 09/09/2021 10:32 am
Honeycomb works well at larger sizes for objects where bending bias matters.  At this scale and density it requires huge numbers of precise direction changes and the heated nozzle dwells too long over each area for good cooling, cubic would be my choice for fill, much kinder to the printer and significantly faster to print.
Napsal : 09/09/2021 3:36 pm
