Splitting layers
Kristaps
(@kristaps)
Splitting layers
Any tips to change settings so i don't have splitting layers? For this print cooling was off for first 3 layers then 30%.
0.6 nozzle. Prusament PETG
Posted : 16/11/2020 5:05 pm
RE: Splitting layers
A few things to check:
  • PETG adheres better with hotter temperatures. Try bumping your nozzle temp 5-10C or reducing any cooling.
  • Lower layer heights will improve adhesion between layers. At 0.25mm with a 0.6mm nozzle, you should be fine.
  • Slowing down can give layers time to better adhere. You're at 20mm/s though, so should be fine.
  • Calibrate your extrusion multiplier to see if you can reduce the gap between wall extrusions.
Posted : 16/11/2020 7:22 pm
