Small radius on bottom edges of print
perky890
(@perky890)
Hi all.
I am trying to print a model with a small 5mm radius on every edge, including the bottom edge that sits against the bed.
When slicing in prusa slicer i enabled the "supports everywhere" option, and it did start to print the supports. The supports elsewhere on the model worked fine, but on the edges with a radius on the  bottom, the supports appear to have stopped short, allowing the print to collapse a little. It has made a right mess of the supported radius'.
Please see the attached images.
Does anybody have an ideas as to how i can get this to work?
Thanks
Opublikowany : 28/02/2024 1:49 pm
