Silk Rainbow filament crisp result
Tina
 Tina
(@tina)
Hi, im one month new at 3D printer.
i have print some clay cutter couple of weekwith Esun PLA + and not have problem.
Today i change filament into Esun Silk Rainbow PLA, and the result is crisp, the cutter is consist 3 layer (base, wall, and edge) these 3 part doesnt stick well, everything comes off.
any suggestion for slicer setting?
im using 0.4 nozzle, try 210~230 nozzle temperature, 58~65 bed temperature. And none working
Respondido : 23/11/2021 9:16 pm
AK
 AK
(@ak-2)
RE: Silk Rainbow filament crisp result
I have actually printed this with prusament slicer setting and it does turn out good. For longer/more detailed projects, I noticed it becomes more brittle. I tried to dry the filament using sunlu s1 filament dryer and noticed increased quality with my prints. Are you storing your filament with silica gel?
Respondido : 29/11/2021 6:07 am
Steverd
(@steverd)
I've had this often with TTYT3D Rainbow filament.
Even with NEW just opened, so I don't "think' it's moist filament.
I've been printing at 215/210' would that make a difference?
Respondido : 05/12/2021 11:22 pm
Silk filaments work by slightly foaming as they print, this gives them their characteristic look but at the cost that they are not so strong.  They look good but they are generally less suitable for functional parts.
Generally they need slightly higher hotend temperatures, check the figures given on the spool.
Respondido : 06/12/2021 1:13 am
2 les gusta
AK
 AK
(@ak-2)
That is good to know and that does explain why it was so brittle. I made a light saber and as soon as I flung it out… the print just crumbled. Learned my lesson!
Respondido : 06/12/2021 3:18 am
jsw
 jsw
(@jsw)
Posted by: @diem
I've had issues with the Mika3D silk metallic filaments jamming in the extruder at times.
IIRC, they say the print range is something like 200-230C, with a suggested print temperature of 220, but I've found I get best results printing around 225.
The issue has been more significant on my other printer, Ultimaker S5, as it defaults to 200C for printing generic PLA.
I've also discovered on the Ultimaker that PETg filaments need a bump in the temperature as well above the Ultimaker default, or else the adhesion between layers is poor, similar to the way one of your samples above looks.
Respondido : 06/12/2021 5:00 am
Use the force...
Respondido : 06/12/2021 1:11 pm
1 les gusta
Tina
 Tina
(@tina)
this is new filament just open from the box. i call seller and they send me new filament  (i request to send me PLA+ instead)
PLA+ worked fine. well i just gave up for this Silk filament
Respondido : 25/12/2021 7:20 am
NeoGeo
(@neogeo)
Miembro
I know this post is old BUT...I do have answers aside from what has been provided / suggested.
Print Speeds:  "Please Adhere to the Print Speeds, initially"  Once you see your first print job works, then you can test with faster printing and see if the filament can handle it.
Regular Print Speed = 30mm/s
Outer Wall Speed= 15 mm/s
Inner Wall Speed = 30 mm/s
Initial Top / Bottom Speeds = 15 mm/s
Temperatures:
Printing Temperature = 220 Celsius "Don't go below this"  Silk Rainbow PLA needs to print HOT and Hotter than the suggested Temp.  210 IS NOT HOT ENOUGH.
Bed Temperature = 90 Celsius "Your Part will unstick itself if you don't have the bed Hot enough.  90 Celsius is Perfect for Silk Rainbow PLA.
Fan Speed / Cooling =  DISABLE.  You "DON'T" want to cool that filament while the nozzle is laying it down on the layer.  It cools it too quick and doesn't actually lay it down properly and adhere.  Just turn the cooling fan off for the nozzle BUT not the body of the hotend, if you have a fan for that.  Only turn that fan off that is directly cooling the nozzle.
Cheers!!!
NeoGeo
Esta publicación ha sido modificada el hace 1 year 2 veces por NeoGeo
Respondido : 07/04/2025 6:22 pm
