Prints getting very thin
steebp
(@steebp)
I'm having an issue where the outside of the walls are getting very thin part way through a print. There should not be any material change to the print at this point but as you can see from the attached images it's getting very thin. Looks like maybe not enough filament is getting extrude and it is making the print porous and weak.
It was printing fine before and no changes were made to the filament being used, or the slicer settings.
I'm printing with default prusa filament settings and PLA from Atomic, .2mm layer thickness.
Respondido : 22/08/2022 4:41 pm
RE: Prints getting very thin
Hello and welcome to the Prusaforum!
A common Prusa Mini problem: hotend clogging.
what to do about it: https://help.prusa3d.com/article/clogged-nozzle-hotend-mini-mini_112011
good luck!
wbr,
Karl
Respondido : 22/08/2022 5:08 pm
steebp
(@steebp)
Thank you!
Respondido : 22/08/2022 5:42 pm
