Printing with PVB
Crymic
(@crymic)
Printing with PVB
Hi!
I have some problem with printing with PVB. Somehow at the end of the filament just curl up at the end of the lines. I tried many options, the filament is in a dryer all the time but its just still dosnt want to work. Anyone have any tipps or hints to make it work?
Thank you!
Opublikowany : 17/09/2023 11:00 am
Hotshot
(@hotshot)
Replace default steel sheet for Satin Powder-coated Steel Sheet. I print everything on it, life is much more easier with this sheet, I didnt have this issue after I switched it...
https://www.prusa3d.com/en/product/satin-powder-coated-steel-sheet/
This post was modified 2 years temu by Hotshot
Opublikowany : 21/04/2024 9:47 am
mark
 mark
(@mark)
RE: Printing with PVB
This is the satin powder sheet for the Mini. The one above is for the bigger machines.
https://www.prusa3d.com/en/product/mini-satin-powder-coated-steel-sheet/
I have never used either the satin powder sheets or PVB, so can't be of much more help.
Regards,
Mark
Opublikowany : 21/04/2024 4:37 pm
I've printed PVB fine with the satin sheet but I don't see why it wouldn't work with smooth. From the picture I'd say the Live Z calibration of the printer is off. Try something like https://www.prusaprinters.org/prints/105404 to finetune it.
Opublikowany : 23/04/2024 11:13 am
