Printing is happening unevenly
Julie Pearl
(@julie-pearl)
Membre
IMG_3679
I've tried washing the sheet with dish soap, cleaning with alcohol wipes, and applying a thin layer of glue stick.  And I've tried multiple sheets.  I keep having the same issue.  I've even tried ensuring that the sheet is level.  I'd appreciate any help!
Publié : 07/10/2025 12:19 am
_KaszpiR_
(@_kaszpir_)
RE: Printing is happening unevenly
Looking at the print video we can see that the filament in tte left front corner is not squished enough ( looks like a squeezed mayonnaise 😉 ), while the back right corner has a smudges over the plate.
This looks like you X axis is too high on the left side of the printer and too oow on the right side of the printer. Please move the print head to the 1mm Z on the right front edge, disable motors and then move the print head to the left front corner and see if there is a height difference. Do the same foe other corners, watch out not to scratch the print sheet.
You need to start with https://help.prusa3d.com/article/squaring-your-mini_158518
Publié : 08/02/2026 8:03 am
