Printing cyclinders - outside surface is muchbetter than inside.
John Sowerby
(@john-sowerby)
ķEvening all.
I've a original mini and I'm printing with semi matt petg.
The model I'm printing is  essentially a tall cylinder. The outside surface prints flawlessly but the inside surface is significantly rougher, more blobs more uneven layers etc.
I'm actually not fussed about the finish of the outside ironically it's the inside I'm using.
Any and all advice welcome
Napsal : 21/01/2024 10:10 pm
_KaszpiR_
(@_kaszpir_)
RE: Printing cyclinders - outside surface is muchbetter than inside.
In PrusaSlicer you can set to print inner perimenters first and also you can pain seam in the place you want it to be, might help.
Napsal : 22/01/2024 11:34 am
Tysonsw
(@tysonsw)
The cooling fan is probably blocked by the walls of the cylinder so the filament isn't cooled enough.
Printer: Original Prusa Mini+
Nozzles: E3D 0.25, E3D Nozzle X 0.4 , E3D 0.4, Bondtech 0.6 CHL
Printables: Tysonsw
Mastodon: tysonsw@infosec.exchange
Napsal : 30/01/2024 9:52 am
