Print quality and stringing
I printed this recently on my Prusa Mini+ and was wondering if I could improve this print quality or whether I just need to sand it. I also experienced a lot of stringing on this and many other prints, is it possible to avoid this? I’m very new to 3D printing as you can tell so any help would be great
RE: Print quality and stringing
Forgot to mention this is with Prusa PLA in galaxy black
Did you print this horizontally or vertically,
and where does the file come from?
See p. 19 of the Prusa manual where the First Layer Calibration is explained.
It is also important that the SPINDA is mounted at the correct height!
Load a light color filament and do a first filament calibration.
The height of the nozzle is correct if you cannot rub the filament off the bed with your finger.
At the rectangle that is printed at the end, the lines must be connected!
So is being in one piece that you cannot see through.
See also https://help.prusa3d.com/article/first-layer-calibration-i3_112364
bottom layers on your frog are not squished enough
Thanks! I think it’s fixed now. The practice came out with no gap between each line so that’s great!
