PC Blend Repeatable Stringing
mark
 mark
(@mark)
I am trying out Prusament PC Blend. I did find that when I unloaded and loaded the filament back up it clogged. I did a cold pull that seemed to get it unclogged, but I know the PTFE tube is fragile especially when running hot.
It seems that it strings, always in about the same place, on the far spaced support. The object itself seems OK. Any suggestions for improvement? Picture is a little fuzzy, as it was moving, but you can see the issue in the diagonal strings toward the top right. Multiple strings on multiple layers follow that pattern.
Regards,
Mark
Postato : 09/05/2022 10:13 pm
mark
 mark
(@mark)
I tried a large object, with temp 280 and a draft shield. It did not pull off the bed, but, about 6 hours into a 12 hour print it started to clog and intermittently stopped extruding.
Note that I was using 20% gyroid infill. That looked OK for the first 6 hours but then it became pretty ratty.
Regards,
Mark
Postato : 16/05/2022 3:46 am
