Outer perimeter opens up, not vertical
Hi everyone, I'm hoping someone can help me fix the problem I'm having with the edge of this coin. The edge of the coin is not vertical, the picture shows its orientation when printed. It's 5 mils thick and as the print head reaches the middle it starts to get larger in diameter. Im using a .25 nozzle 215-220 c . Have tried a print with origanal Prusa Slicer .25 setting with same result. Im printing on a new Mini plus using Prusa slicer. I did print a cylinder on the Mini, and it turned out perfect. All the prints on the Mini turn out great except for the coins edge. I didn't have this result using Cura on a Creality 6 SE.
Postato : 26/03/2023 11:06 pm
