Nylon printing
Riho
 Riho
(@riho)
Nylon printing
Hello,
Has anybody tried to print Nylon using Prusa Mini?
I cant find the right settings. Tried with 150-160C hotend temperature, with 60-70-100C bed temperature. It dows not want to stick very well to the bed and is pretty likely jamming to the nozzle.
Nylon is from HobbyKing, PA-CX12.
Does anybody have a profile that is working? Maybe not only material configuration matters but also printing speeds?
I used Prusa PETG as a starting point for configuration. Maybe something else suits better?
Veröffentlicht : 08/02/2020 9:08 pm
neek
 neek
(@neek)
RE: Nylon printing
According to Prusa's site ( https://www.prusa3d.com/material-guides/ ) you want to probably raise your nozzle temp to 240 degrees and your bed to 80-90 degrees
Veröffentlicht : 09/02/2020 8:42 pm
RE: Nylon printing
@neek
Not the right section, but i'm printing successful nylon (Aprintapro PA12) with nozzletemp 270degrees C and bedtemp 105degrees C with a MK3. Maybe it also works with lower temperatures, but 160degrees C nozzletemp is too low.
Veröffentlicht : 09/02/2020 8:55 pm
Nikolai
(@nikolai)
RE: Nylon printing
Posted by: @riho
Specs from the website:
Specs:
Width: 1.75mm
Weight: 500g
Colour: Black
Tensile Strength at Yield: 60 MPa
Strain at Yield: 0.08
Strain at Break: >150%
Tensile Modulus: 1400 MPa
Flexural Modulus: 1700 MPa
Flexural Strength: 90 MPa
Impact Strength - Charpynotched 23˚C: 14 kJ/m2
Moisture Absorption: 3,5%
Printing Temper: 240-260°C
Melting Points: 250°C
Shore D Hardness: 81
Start with 250C nozzle temp and go up. Consider using glue for better adhesion to bed.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Veröffentlicht : 10/02/2020 8:32 pm
straylit
(@straylit)
RE: Nylon printing
@karl-herbert
The MK3 is explicitly stated to support Nylon unlike the Mini.
I would like to know why Nylon support is left off of the officially supported materials list for the Mini.
Perhaps there are some modifications that should be made for a successful+safe print.
Veröffentlicht : 11/02/2020 12:59 am
Nikolai
(@nikolai)
RE: Nylon printing
@acortelyou
Most likely because it's not advised to run 280C on a mini all the time (same like 300C on MK3).
Often linked posts:
Real Multi Material
Veröffentlicht : 11/02/2020 1:41 am
straylit
(@straylit)
RE: Nylon printing
What do you mean by all the time?
A certain duty cycle?
A number of hours at a stretch?
I just want to be able to print a drone frame out of Onyx every now and then with the Mini.
Thanks!
Veröffentlicht : 11/02/2020 3:26 am
nic
 nic
(@nic-3)
RE: Nylon printing
@acortelyou
It's not necessarily unable to print nylon. It's that nylon isn't a "supported" material; meaning that Prusa doesn't provide filament profiles for nylon on the Mini. The Mini is targeted towards a different demographic than the MK3. It is what it is.
I printed Taulmann Bridge on my MK3 with good results at ~250c on the hotend. I would think you could have similar results on a Mini.
Veröffentlicht : 11/02/2020 6:31 am
Crawlerin
(@crawlerin)
RE: Nylon printing
@nicholas-m12
Taulman-Bridge profile is listed under MINI in Prusa Slicer.
Veröffentlicht : 11/02/2020 10:34 am
Riho
 Riho
(@riho)
RE: Nylon printing
I got it almost printing with 170C hotend and 100C bed. It was important to limit the  speed to 25mm/s. I used also a 3mm raft. Everything is starting fine but after around 10minutes the nozzel will be always completly jamed.
I dont have that problem with ohter materials. What can cause the problem? Shall I rise the temperature even more?
Veröffentlicht : 11/02/2020 3:54 pm
nic
 nic
(@nic-3)
RE: Nylon printing
@crawlerin
Really? Good news!
Veröffentlicht : 11/02/2020 6:09 pm
neek
 neek
(@neek)
RE: Nylon printing
@riho
Again according to that link I cited above, Prusa claims that particular nylon needs a much hotter temp to extrude. It might put more wear and tear on the mini but that's what the material seems to require.
Veröffentlicht : 11/02/2020 6:53 pm
Nikolai
(@nikolai)
RE: Nylon printing
Posted by: @riho
Seriously? Spec sheet is telling you 240-260C, people are telling you here to go over 240C and you're still printing with 170C and asking for help?
Often linked posts:
Real Multi Material
Veröffentlicht : 11/02/2020 6:55 pm
Riho
 Riho
(@riho)
RE: Nylon printing
@crawlerin
I just ordered it on Monday. Hopefully receiving it soon and can test.
Veröffentlicht : 11/02/2020 7:20 pm
straylit
(@straylit)
RE: Nylon printing
I reached out to Prusa support directly and this was their response:
We haven't yet tested Nylon at the time of release.
You can print Nylon with MINI just fine, there is also a Slicer profile for it as well 🙂
The product page will be updated accordingly soon.
Veröffentlicht : 12/02/2020 6:05 pm
Riho
 Riho
(@riho)
RE: Nylon printing
Just finished testing and can confirm that with the Taulman Bridge profile both Taulman Alloy 910 and Taulman Bridge are printing perfectly.
Bed temp 90C, Nozzle 255C
Diese r Beitrag wurde geändert Vor 6 years von Riho
Veröffentlicht : 13/02/2020 5:12 pm
Crawlerin
(@crawlerin)
RE: Nylon printing
@riho
This is good to know, thank you 🙂
Veröffentlicht : 13/02/2020 11:50 pm
