Need help with print failures
Butch Alline
(@butch-alline)
I have printed many objects successfully until now.  This is what I am trying to print:
Three tries produced only this after only a few printed layers:
Using Elegoo PLA filament recently opened, Prusa slicer 2.7.1 set to defaults.
Print settings 0.15 Quality & 0.10 detail.  Printer is at room temp with enclosure.
Printing upwards from blue base in top image. Z axis dimension is 167mm.
Calibration before printing attempts is shown in rectangle in lower image.
Slicer gave stability warning but adding brim produced no joy.
Is there some "rule of thumb" for ratio of height to first layer area?
Any and all help and hints appreciated!
Posted : 17/02/2024 9:20 pm
Files > Save Project as
Posted : 18/02/2024 8:52 am
Butch Alline
(@butch-alline)
RE: Need help with print failures
I am using Inventor and cannot save in .3mf  🙁
Here are the file types that Inventor can export:
Can you use any of these file types?
If not, can you recommend a file converter?
Thanks
Posted : 18/02/2024 9:18 pm
OBJ May work. but you will have to Zip Compress the file in order to attach it
Joan
Posted : 18/02/2024 9:29 pm
mark
 mark
(@mark)
Posted by: @butch-alline
Thanks
You said you were using Prusa Slicer in the first post. Prusa Slicer makes the .3mf files.
Regards,
Mark
Posted : 18/02/2024 10:18 pm
I also work with Inventor and always export my designs via the STL interface.
Settings:
wbr,
Karl
Posted : 18/02/2024 11:05 pm
After you have imported the STL file into PS and set the parameters, you can save the project as .3mf using "Save as".
wbr,
Karl
Posted : 18/02/2024 11:10 pm
Butch Alline
(@butch-alline)
Diem,
Are any of the Inventor save files acceptable for your analysis?
Posted : 19/02/2024 2:17 pm
Butch Alline
(@butch-alline)
Here is a .3mf file of the object saved and zipped.
Using Prusa slicer ver. 2.7.1
CT2 rear hull 4 - Copy
Posted : 19/02/2024 2:40 pm
Prusa Slicer reports an error in the STL.
Otherwise looks OK! at a quick glance,
I Don't have a mini to try it on.
Have you made sure the build plate is scrupulously clean?
Have you tried 7oC on heatbed
Joan
Posted : 19/02/2024 4:14 pm
mark
 mark
(@mark)
Prusa slicer warns it has print stability issues and suggests to add a brim and supports. Adding a brim helps it stay on the bed. The supports comment may not be useful. Even when enabled it does not add much.
Make sure your first layer calibration is correct.
https://help.prusa3d.com/article/first-layer-calibration-mini-mini_229122
Maybe even adjust your sensor first, then redo the first layer calibration.
https://help.prusa3d.com/guide/height-adjustment-of-m-i-n-d-a-superpinda-sensor-mini-_154547
Regards,
Mark
Posted : 19/02/2024 10:30 pm
languer
(@languer)
First and foremost, clean the bed with warm soap water.
Maybe try adding a one or two more perimeters, add Detect Thin Walls, increase the Bed Temp for Other Layers by a few degrees; and if else fails maybe add your own "brim" on the inside since the sidewalls that go all the way to 167mm are thin (to keep it all together from coming off the plate as is building up.
Are you using Octoprint? Have you tried without Octoprint?
Are you using the InputShaper? Havve you tried not using that?
Lastly; go slower.
Posted : 20/02/2024 2:03 am
Just for a change this is not a first layer or bed adhesion issue.  I expect the first layer is sticking OK - but it's tiny and the majority of the part is hovering, unsupported, one layer above the build sheet.
The narrow, angled, lip on the underside of the part (circled) is holding the rest above the sheet where it is too high to stick, and too low for any support to fit underneath.
Remove it and the print should stick.
Posted : 20/02/2024 5:58 am
languer liked
_KaszpiR_
(@_kaszpir_)
Or use raft if you cannot change the model or use thin negative volume to make it flat.
But because you have a source model it is better to fix it directly on the design.
Posted : 20/02/2024 7:08 am
Thejiral
(@thejiral)
The easiest thing will be to use the cutting tool in Prusa Slicer to remove a few hundred micrometers from the bottom, as much as is needed to make the bottom flat. Doesn't look like it would need much. I would not expect that this small elevation is needed and even if it is, witha raft the precision might be even lower than if you just print it properly flat.
Posted : 20/02/2024 9:05 am
Butch Alline
(@butch-alline)
Many thanks for all the suggestions and a special thanks to Diem for spotting what my 85 year old eyes missed.
I will correct the drawing and try another print.
Posted : 20/02/2024 11:25 pm
My Myopic eyes missed that!  Well done Diem!
Posted : 20/02/2024 11:59 pm
< FX: Blush>
Posted : 21/02/2024 8:17 am
mark
 mark
(@mark)
Yes, thanks @diem. I missed it too. You are truly illustrious!
Regards,
Mark
Posted : 21/02/2024 11:34 am
