Mistery random layer shifting with PLA
MarsDropper
(@marsdropper)
Although prints are mostly ok, after upgrading the bearings to the Mini I am getting these ugly layers randomly in my prints. The quality print is also not as great as before even using the same settings.
I just changed the bearings from X and Y axis to Mizumi ones using the super lube included. After that, just some cleaning. I printed a couple of different pieces and the ugly layers do not appear in the same height, so they are random and we might discard a mechanical issue. They show in both axis.
Troubleshooting:
- I have tried both prusament and cheap filaments. They are somewhat dry and there is hardly any stringing.
- Tweaked the belts tension, should be as before. I had overtightened them and now they should be fine
- Tightened both motor´s gear screw, made sure they are aligned
- Squared the printer
Do you have any ideas of why can these layers appear?
Thanks everyone.
Posted : 13/04/2023 4:46 pm
MarsDropper
(@marsdropper)
RE: Mistery random layer shifting with PLA
I have also reduced the speed in not printing movements to 100mm/s
Posted : 13/04/2023 5:21 pm
