Mini shuts off mid print
nighthawk
(@nighthawk)
So my new Mini is shutting off mid print. It acts like someone hit the reset button. The print head will sit there where it stopped. This is a new Mini, factory assembled. I tried different files and a different flash drive.
Anybody have any idea what to do?
Publié : 08/12/2021 6:37 pm
nighthawk
(@nighthawk)
RE: Mini shuts off mid print
It was working fine the first few weeks the I had extrusion problems. Now It prints well until it resets.
Publié : 08/12/2021 6:43 pm
BogdanH
(@bogdanh)
What firmware is installed? I ask, because older firmware (before v4.32, I think) had troubles with some flash drives.
[Mini+] [MK3S+BEAR]
Publié : 08/12/2021 9:23 pm
nighthawk
(@nighthawk)
I just got it about 3 weeks ago so it should have the latest. I can check for sure.
I tried a bit more after making sure all the cables are tight. I checked after about 3 hours and the print bed was pushed all the way off and the printer was making a birds nest. Now the bed leveling fails. I can see the X axis is skewed so I'll have to check that out when I get home from work.
Publié : 09/12/2021 10:33 am
Membre
Support by chat may be the best option.  Either way, not enough information above to assist.
Posted by: @nighthawk
Publié : 09/12/2021 11:13 am
