Marble Jet filament and profile
LopCot
(@lopcot)
Hi
I'm new with my PRUSA Mini (and very satisfied for the printing quality with small object).
I'd like to test some print with Filament PM Marble JET PLA (usually i use prusament filaments, just to avoid troubles, but i'd like to try something different). Has anyone tried it before? Unfortunately i can't find any profiles in PrusaSlicer.
Also do you know some reliable marble like filament?
Best Answer by Diem:
The gcodes provided with the printer are configured to match the free filament, which, in all cases I know of, is Prusa (effectively Filament PM), not Prusament.  If you have Prusament samples, slice for Prusament.
Opublikowany : 10/11/2021 9:18 am
I don't know that particular filament but as a general rule for Filament PM use Prusa (not Prusament) settings.
Opublikowany : 10/11/2021 9:59 am
1 ludzie polubili
LopCot
(@lopcot)
RE: Marble Jet filament and profile
Ok thanks, i will try it and let you know if i have troubles with PRUSA PLA profile.
Opublikowany : 10/11/2021 10:22 am
LopCot
(@lopcot)
I have seen now that gcode inside PRUSA USB have the PRUSA PLA profile set and not the PRUSAMENT PLA profile (as they give some PRUSAMENT sample filaments).
Is there a reason for this? If i use PRUSAMENT filament, is it better to use PRUSAMENT PLA profile and not PRUSA PLA profile, is it correct?
Opublikowany : 10/11/2021 11:15 am
Opublikowany : 10/11/2021 11:25 am
1 ludzie polubili
LopCot
(@lopcot)
Hi Diem
I have found "Plasty Mladec PLA" inside profile list... is it Filament PM (Plasty Mladec) or it's something different?
PS.
I have tested the PRUSA frog with PRUSA PLA and it's printed nicely.
Opublikowany : 10/11/2021 4:09 pm
Posted by: @lopcot
Hi Diem
So it is, I hadn't noticed.  Yes, that's the same company (or parent.)
Opublikowany : 10/11/2021 6:19 pm
