learning g code
geert
(@geert)
learning g code
hi,
Since an update an adjustment has happened that I don't like
the print head sits on the print bed and is very firm
how do i fix ths? which code do I modify
thanks in advance
geert
Opublikowany : 04/11/2025 6:06 pm
_KaszpiR_
(@_kaszpir_)
RE: learning g code
that shouldn't happen, try factory reset and ensure to have prusa slicer profiles updated and reslice the model
Opublikowany : 04/11/2025 8:00 pm
1 ludzie polubili
geert
(@geert)
RE: learning g code
did forgot to mention, this happens after the print ha finished
already thanks for the reply
Opublikowany : 04/11/2025 8:03 pm
_KaszpiR_
(@_kaszpir_)
RE: learning g code
can you attach the used gcode? (first make a zip and use media to add it)
Opublikowany : 04/11/2025 8:28 pm
