How to remove a PETG print
StinkyPete
(@stinkypete)
I'm a 3d Print newbie and thought I'd have a go a printing PETG, as it seems to be a better choice than PLA for structural/water resistantance/UV resistance.    I am printing onto my smooth steel PEI sheet.    The prints are REALLY difficult to remove, and have even stripped small bits of the first layer as the print eventually comes away.  There is  a white residue left on the PEI sheet once the print is removed.      Prior to printing I clean the sheet with IPA.
Any suggstions for PETG print removal and cleanup of the sheet afterweards would be welcome.
Publié : 09/06/2020 9:17 pm
RE: How to remove a PETG print
Read through the manual and you'll find a section on printing recommendations for different materials. For PETG, it specifically notes that you want some sort of release agent on the PEI sheet to avoid damage. A spray with Windex is recommended by Prusa. Many have found a few wipes with the fingers suffice. In extreme cases, apply some gluestick to help reduce the grip of the filament to the PEI. You may also want to raise your Live-Z setting in the range 0f 0.02-0.2mm since PETG doesn't need the squish PLA does.
Publié : 09/06/2020 9:36 pm
StinkyPete
(@stinkypete)
Thanks for the prompt reply bobstro.   I had read the "Windex" suggestion in the manual, and wrongly assumed that it was mostly alcohol, but there's plenty of other stuff  in there as well.  Anyway, I gave it a try with the same print I ran yesterday, and although stuck well, the print came off without any problems.    I might keep one side of my PEI sheet for PLA and the other for PETG.
Publié : 10/06/2020 6:43 am
mark
 mark
(@mark)
@stinkypete
Windex (the blue kind) has been working pretty well for me. I clean with IPA once in a while but before each print use a good squirt of Windex on the cold bed and wipe it around, covering everything so it is completely wet and then let it air dry. After three months of 16 hour a day use with PETG I pretty much wore one side out and flipped it over to the other side. There still is some white residue that remained and some gauges started to come off.
I use a combination of plastic razor blades and a cookie spatula to help get things off. Once you bend the flex plate and get one corner to separate, it is much easier to get the rest off. Small and thin pieces like the PPE ear savers are the hardest as flexing the plate doesn't help start things off.
Regards,
Mark
Publié : 10/06/2020 10:41 am
1 personnes ont aimé
steve
(@steve-13)
Using IPA before printing PETG is exactly what you should not do. As noted above Prusa suggests to use Windex or even glue stick. I do exactly what @marklgoldberg does for PETG - wipe the sheet down so it's very wet with Windex and let it air dry (it only takes a minute). The PETG prints pop right off.
Remember the print sheet is a "consumable" product meaning that you should expect it to wear out over time; PETG definitely accelerates this and removes a tiny amount each time you remove a print from the sheet. It's not a big deal if you're a casual printer switching between PLA and PETG, but if you print with PETG constantly you will visibly see the effect.
Also - I'm not sure exactly what in Windex does the trick as a release agent (Windex does have something in it that makes a soapy-like foam) however I noticed there are 3 or 4 types including (in my store) a "WINDEX AMMONIA-FREE GLASS CLEANER". I don't know if the other types are better or worse so I go out of my way to find "Original" (which has been a challenge until recently due to Covid).
Good luck!
Publié : 10/06/2020 11:00 am
Crawlerin
(@crawlerin)
@steve-e3
I use whichever windows cleaner I have at hand, I think last I bought from nearby shop, and they work OK. I think most important is that it leaves some residue from all those perfumes and polishing components and PETG is not printing on PEI directly.
Publié : 10/06/2020 1:03 pm
kevman
(@kevman)
What about using the textured steel sheet for PTEG ? Would that require the surface prep such as windex or glue sticks?
Publié : 10/06/2020 1:49 pm
Membre
I always do a small test print with PETG.  If it is a very sticky filament, I use Windex to prep the bed.  It reduced adhesion post-print.
I have a small bottle that I refill for spraying.
Publié : 10/06/2020 2:24 pm
Crawlerin
(@crawlerin)
Posted by: @kevman
I just wash it with dish soap once in a while and clean with IPA between prints, nothing else.
Publié : 10/06/2020 2:39 pm
steve
(@steve-13)
@kevman
Yes - same for textured sheets.
Publié : 10/06/2020 3:27 pm
3Dprintedgr
(@3dprintedgr)
I use glue stick on my smooth sheet. So far every print comes out pretty easily once you flex the sheet.
Original Prusa Mini + Smooth PEI
Prusa Slicer 2.6.0
Publié : 14/06/2020 12:37 pm
Membre
@geoper2
I don't need it with PLA.
Publié : 14/06/2020 2:43 pm
jsw
 jsw
(@jsw)
My PETg prints always seem to pop right off of the textured sheet after cooling to room temperature and giving a few gentle bends to the sheet.
I really think that having the patience to let a hot print cool helps quite a bit in the removal, for almost every type of print.
Publié : 14/06/2020 4:56 pm
Membre
@jsw
How old is your sheet?  While what you say is true for a new sheet, it might not be in 12-16 months.
Publié : 14/06/2020 4:59 pm
3Dprintedgr
(@3dprintedgr)
@charles-h13
When I recommend using glues tick I am only talking about PETG prints . PLA doesn't need a medium to come off. On the contrary I use IPA after a couple of prints with PLA in order to have better adhesion.
Prusa Slicer 2.6.0
Publié : 14/06/2020 5:10 pm
Membre
Posted by: @geoper2
@charles-h13
That is definitely true.  You have to clean the bed regularly to maintain adhesion.
Publié : 14/06/2020 5:56 pm
