How do you print a MK3s Parts Fan Duct? What is the trick what are your settings
Crunch
(@crunch)
How do you print a MK3s Parts Fan Duct? What is the trick what are your settings?
I am trying to replace my parts fan duct in ABS I can only get a good print do you print flat on end what supports settings do you use
If I include supports inside in and out problem is it is impossible to remove the supports inside the fan
The Latest Firmware can be found here https://github.com/prusa3d/Prusa-Firmware/releases
Open Firmware Issues https://github.com/prusa3d/Prusa-Firmware/issues
Opublikowany : 05/11/2019 7:20 pm
teookie
(@teookie)
RE: How do you print a MK3s Parts Fan Duct? What is the trick what are your settings
I believe the stl file from prusa github has built in supports; you should be able to print it fine with "no supports" selected in prusa slicer.
Minimum layer time can be a problem at the end of the print while printing the square not slot. To get around this print 2 or more fan ducts at a time. The first will have time to cool while the other(s) are printing.
ABS can be tricky due to warping. Put a cardboard box over the printer to eliminate drafts. You can also make the skirt the same height as the part for a similar effect.
Turn part cooling fan down real low, or off completely.
Opublikowany : 05/11/2019 7:39 pm
Texy
 Texy
(@texy)
Posted by: @mk3betatester
You are asking this in the Mini forum ?
Opublikowany : 06/11/2019 12:42 pm
1 ludzie polubili
Greybeard3D
(@greybeard3d)
The parts fan duct is already ABS.
Opublikowany : 15/12/2019 5:43 am
Crawlerin
(@crawlerin)
Maybe OP has MINI and is printing parts for another printer? 🤷‍♀️
That part should already be ABS, people rather print it with carbon fibre composits or other high temperature resistant materials.
Opublikowany : 15/12/2019 12:20 pm
Texy
 Texy
(@texy)
Posted by: @crawlerin
He wouldn't have a Mini on the 5th November! (Unless he was a Beta tester, but someone in that category wouldn't be asking those types of questions).
Texy
Opublikowany : 16/12/2019 4:23 pm
Crawlerin
(@crawlerin)
@texy
Ops, sorry I overlooked the date.
Opublikowany : 16/12/2019 11:27 pm
