How do I get the Mini to center prints on the bed?
I printed a part that was a full 180 mm wide. In the prusa slicer the part was centered on the bed. When it printed, it was about a 6mm off to the right. This put the print off the heat bed and cause a corner to lift. Is there something I can adjust on the printer or Prusa Slicer to shift the prints over on the X axis?
Here are some pictures of the part not centered. I also printed a small bed level test square and you can see how it is shifted to the right.
Publié : 17/07/2020 2:56 pm
RE: How do I get the Mini to center prints on the bed?
I have the same issue, almost the exact same amount of offset too. I found this thread, I think you'll find the answer there. i haven't tried to solve it yet myself.
https://forum.prusa3d.com/forum/assembly-and-first-prints-troubleshooting/heatbed-not-centered/
Publié : 18/07/2020 2:44 am
