Holes in the print result
Bazim
(@bazim)
Hello,
can you help me what I can do against the small holes in the prints? I attached a picture of the holes. Is it only the random seam or is it some other issue?
Print on the picture is from PETG.
Thank you already for your help.
Publié : 09/06/2022 6:52 pm
mark
 mark
(@mark)
RE: Holes in the print result
Posted by: @bazim
Hello,
Start with drying your filament.
Regards,
Mark
Publié : 09/06/2022 9:57 pm
Bazim
(@bazim)
Oh OK, it was almost new Prusament PETG, but I will put it to the dryier I have got (Sovol). Thank you. Will try. Any other tips and tricks for this?
Publié : 10/06/2022 12:56 pm
Tux
 Tux
(@tux-3)
Membre
I had something similar last year and 2 things helped me:
1) Clean out my extruder gears, there was a lot of debris in there
2) Replace the extruder with a Bondtech extruder made my retractions more precise
Publié : 16/06/2022 3:21 pm
Bazim
(@bazim)
1 is done and about the second point. I think I will buy the bondtech extruder.
Publié : 17/06/2022 8:30 pm
sandysasmita
(@sandysasmita)
Before you buy bondtech extruder, just try to reduce retraction from default 3.2mm to 2.0mm ... many of mini user fix this issue by reducing retraction length in prusaslicer...
Publié : 18/06/2022 10:34 pm
Bazim
(@bazim)
Wait what? Decrease a retraction? For examle, for me helped the other way. Increase retraction from 3,2mm to 4,5mm helped me with the PETG stringing a lot.
Publié : 19/06/2022 5:13 am
mark
 mark
(@mark)
Posted by: @bazim
Yes, I have found that increased retraction helps with stringing but causes problems with surface finish. Drying the filament improves stringing with no bad side effects.
Regards,
Mark
Publié : 19/06/2022 5:20 am
Bazim
(@bazim)
Filament was dried. I can try it, but I think with 2mm retraction I will have so much stringing (I had with the default one 3,2mm already very much stringing everywhere).
Publié : 19/06/2022 6:38 am
sandysasmita
(@sandysasmita)
I'm printing PETG with 2.0mm retraction and printing PLA with 1.0mm retraction with minimum stringing... here some sample PETG stringing test
Publié : 19/06/2022 8:21 am
Bazim
(@bazim)
Oh that is really nice what you got there.
ATM I tried this:
Default 3,2mm :
Changed to 4,2 mm:
So I don't know if I can decreasing the retraction. I guess every machines is different.
Publié : 19/06/2022 8:34 am
sandysasmita
(@sandysasmita)
I don't know if your machine is different, i have three mini's and all of them using same settings, same gcode... 3.2mm only works with prusament PLA galaxy black, others than that will create holes in print walls, so i reduce the retraction to get smooth print and with that retraction almost no stringing or very minimum stringing.
Publié : 19/06/2022 8:43 am
Bazim
(@bazim)
Can you send me a 3mf file with your settings for PLA and PETG to check/try it out please? Are these settings with PRUSAMENT?
Publié : 19/06/2022 8:48 am
sandysasmita
(@sandysasmita)
i don't save the 3mf file, but i have the gcode file... you can import settings from that gcode to your 3mf, note that the filament i use is from eSUN brand
FYI, if you hover the mouse pointer for a few seconds at retraction length settings, there is a pop up information that says default value : 2
Ce message a été modifié il y a 3 years 3 fois par sandysasmita
Publié : 19/06/2022 9:20 am
Bazim
(@bazim)
Ye but that default text is wrong. I already discuss that with the official support. Default for MINI js 3,2mm as the knowledge says. I will try these settings, but maybe is because I am using PRUSAMENT only. So maybe it needs differenet settings. I see you have lift Z turned off? I think default is 0,2mm and I am trying 0,07mm. Will try the 2mm retraction with PRUSAMENT. Thank you for the tips.
Publié : 19/06/2022 9:27 am
sandysasmita
(@sandysasmita)
I don't change any settings other than retraction and temp...
Publié : 19/06/2022 9:29 am
Bazim
(@bazim)
OK, thank you. And I do not want to create a new topic. Can you tell me what are these groves?
In the slicer on model there are not ( https://www.printables.com/cs/model/52161-3d-printer-tool-tote ). Why are they there and why only on this positions?
Publié : 19/06/2022 3:30 pm
sandysasmita
(@sandysasmita)
That is seam position, you can change it from nearest to aligned.
Publié : 20/06/2022 12:33 pm
Bazim
(@bazim)
Oooo now I can see. You can even show the seam in the g-code viewer. Thank you very much.
Publié : 20/06/2022 1:42 pm
