Help!! I'm dying 😭😭😭
Daniel Bonifaz
(@daniel-bonifaz)
I need help 😭  I were able to print 2 tiny pieces for the very fisrt time with my Prusa i3 Mk3s (pictures next messages), the filament was PLA Carbon fiber 1.75mm, but it took me a while to calibrate the printer, anyway, after 4 hours the job was done. But...  Now i can't print.
I try with different kind of filaments, with the correct temperatures, and of course good calibration with every attempt, but now (after the one and only good impression) the nozzle drags (after .5mm more or less) the extruded filament on the print bed. So i can't print anything new after the first (and successful) try.  The firmware is up to date, every selftest is ok, every wizzard calibration says "XYZ calibration ok. X/Y axes are perpendicular. Congratulations!"
I have moved the probe in very different possible height, but the problem stays.   Please help. Greetings from México.
Posted : 18/09/2020 10:30 pm
RE: Help!! I'm dying 😭😭😭
Did it Jam?
Posted : 27/09/2020 11:29 am
Crawlerin
(@crawlerin)
I don't see pictures, but still, I'd suggest starting with cleaning steel sheet properly, if nozzle is dragging first layer from bed it may not stick. What sheet you use, textured or smooth? Either way, give it thorough wipe with 90%+ alcohol and don't ever touch the surface. If you use textured, that may require extra cleaning with dish soap and thorough rinse, and rather switch to smooth sheet with PLA.
Posted : 30/09/2020 12:00 pm
Posted by: @bonifazdaniel
For the beginning I would leave out the carbon material and work with PLA or PETG. Probably it will be good if you clean the hotend and the nozzle properly. Just try it with a "coldpull".
And don't forget - absolutely clean and grease-free printing bed!
Z-firstlayer adjust: https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/life-adjust-z-my-way/
Posted : 30/09/2020 12:19 pm
