Ghosting/rippling on Prusa Mini
I was printing things as normal and suddenly this has begun to happen:
Printed with PLA, 0.25 nozzle and 0.05 layer height. This issue persists after I've set print speed to 25 mm/s, cleaned my entire printer (cold pull, fans, extruder, smooth rods) and retensioned belts. Due to ghosting entire model becomes brittle and miniatures which I print lose detail. Is there a procedure omitted? Should I perhaps check if isn't a software problem?
Respondido : 13/02/2021 3:54 pm
