Fundamental misunderstanding: Top layer never appears in slicer
henryci
(@henryci)
Hello, I've had tons of success with my Prusa but I keep running into this problem and could use some help. I have a square-ish object with a flat top. On the top I have some detail (in this case some pretty simple flat surfaces). When I slice the object in Prusa Slicer with default settings, it always ignores everything on the top. I usually work around this by rotating my object but today is the day I learn what is going on. See the attached pics. You see the object in the slicer and then you see the sliced result:
Publié : 19/11/2021 11:45 pm
henryci
(@henryci)
RE: Fundamental misunderstanding: Top layer never appears in slicer
And the answer is there is an option for "detect thin walls". All is well now!
Publié : 20/11/2021 12:57 am
Yes. Detect thin walls can help but it can also have undesired side effects elsewhere in a model. I think it's better to design upfront with the capabilities of the printer in mind.
Publié : 20/11/2021 4:20 am
1 personnes ont aimé
