Formfutura not "compatible", anyone using rPET successfully?
I noted that Formfutura filaments are listed as "incompatible" in PrusaSlicer for Prusa printers (Mini specifically), but thought I had seen some folks were using anyway. Have any of you used their rPET in your Mini successfully and if so, what settings worked best for you?
Opublikowany : 15/09/2021 2:55 pm
RE: Formfutura not "compatible", anyone using rPET successfully?
I've been able to print rPET successfully with a few modifications to the "Generic PETG" settings on the slicer. I took the hotend temp down to 230 C and the bed temp to 80 C.
Opublikowany : 07/10/2022 6:28 pm
