Filament change mid print ??
Sfbrain
(@sfbrain)
Hi Guys
Has anyone managed a filament change mid print ?
If someone has, how did you do it ?
I've tried a couple of times (using change in Prusaslicer), but it just hangs ?
Cheers
S
Publié : 04/01/2020 1:04 pm
Crawlerin
(@crawlerin)
RE: Filament change mid print ??
Changing filament both mid-print and in general is a bit wonky right now, we may need to wait for firmware update to improve it.
Publié : 04/01/2020 2:17 pm
3Dprintedgr
(@3dprintedgr)
I have printed dual filament prints 3 times until now with success. I used the color change in Prusa Slicer. Using the last version of both the slicer and the Mini didn't create any errors so far.
Original Prusa Mini + Smooth PEI
Prusa Slicer 2.6.0
Publié : 12/07/2020 3:53 pm
mark
 mark
(@mark)
With Firmware 4.1.0 it works perfectly every time I have tried it. Just change color in Prusa Slicer. It will stop and eject the old filament, allow you to load the next color, purge and continue where it left off. Grab the glob of purged filament before saying yes to the color being correct. It continues right after that.
Regards,
Mark
Publié : 12/07/2020 6:49 pm
1 personnes ont aimé
atomleef
(@atomleef)
I also change esun pla white to esun pla+ black no problem found.
Do you use change filament color in mid print feature? Or you make it manually, is it same kind of filament?
If it is all set right, suggest contact to prusa.
Publié : 03/08/2020 4:36 am
pman
 pman
(@pman)
@marklgoldberg
I am trying to do this, but the reloaded filament will not advance past the insertion point. Is this normal, or should it be up to the extruding point before I hit continue?
Publié : 18/08/2020 11:44 pm
mark
 mark
(@mark)
@pman
You hit continue, it loads the filament into the extruder, then heats up, finishes loading and purges. Then you answer yes to the color being correct and it continues printing. Is your firmware up to date? I don't think it worked on early firmware.
Regards,
Mark
Publié : 19/08/2020 4:01 am
