"cheapest" rigid vertical wall?
Andrey Maslyuk
(@andrey-maslyuk)
Hello,
I am making a test model to measure and correct printer skew.
This one works for me fine, but I wonder if there is a good way to improve it making faster to print.
These are two 4mm thick walls; but even with min infill and single-layered it takes 2+ hr to print.
The purpose is to make a rigid vertical square for further measurements and its only requirement is to be rigid enough to be printed straight with no degradation during print.
Any ideas welcome.
TIA
Veröffentlicht : 13/12/2021 6:22 pm
Have you tried vase mode?
Veröffentlicht : 13/12/2021 8:29 pm
Andrey Maslyuk
(@andrey-maslyuk)
RE: "cheapest" rigid vertical wall?
@diem, not yet, but how it may help here?
Would it save on print time?
Veröffentlicht : 13/12/2021 11:19 pm
Why do you need 4 mm walls? If I understand correctly what you're trying to accomplish, much thinner walls such as 1.2 or max 2mm should give you all you need.
Veröffentlicht : 13/12/2021 11:44 pm
Single thickness walls can still be measured and don't take long to print.
Veröffentlicht : 14/12/2021 7:05 am
Andrey Maslyuk
(@andrey-maslyuk)
@fuchsr, yes, would 1.2 mm and 90 mm high flat wall stable enough to print?
I'll try PLA for a test; thanks.
@diem, I am not sure if this high flat wall would be stable enough; maybe making it a hollow 90x90x4 mm "well" would work?
Doesn't sound stable enough not to warp during print.
Veröffentlicht : 14/12/2021 4:30 pm
I don't think that would be a problem. You could also print with a brim to stabilize it.
Veröffentlicht : 14/12/2021 5:26 pm
