RE: Blobs On Underside of ASA Print
@marklgoldberg
Looks like random/near seam. Change this setting
This post was modified 6 years ago by mobile4you
Posted : 09/04/2020 4:57 pm
Topic starter
answered:
@marek-w6
Yes, there are blobs where the seam is, but there are blobs in other places also.
Regards,
Mark
Posted : 09/04/2020 5:25 pm
Without seeing your model its hard to debug, but....... the issue gets progressively worse as the hole gets smaller. Given that the overhang angle is the same all the way up that would suggest that the issue could be heat related. The time area is smaller and its pumping hot plastic into a smaller and smaller area. Seeing as ASA profiles usually have the fan on at very low % speeds it is probably tied to cooling. Could be 'slow down if print time is below' related....
As I say without seeing your project with the model and all its settings its pure guess work.
Posted : 09/04/2020 6:08 pm
