assistance with custom Gcode
I need some assistance with custom Gcode in the Prusa slicer. Specifically, I am trying to skip layers and have tried the following Gcode:
M201 Z0.2 ; set layer height to 0.2mm M73 P50 ; print 50% of the layers M220 S0.8 ; set extrusion multiplier to 0.8 M212 X0 Y0 ; set extrusion offset to zero
While I understand that it is possible to remove layers from the Gcode file, I am looking for a solution that is easier to implement.
In addition, I am interested in printing new parts on top of already printed parts by setting the XYZ values. Is this something that can be accomplished with custom Gcode?
I appreciate any guidance or resources you can provide.
Thank you,
Veröffentlicht : 28/12/2022 11:57 pm
What are you trying to do?
Veröffentlicht : 29/12/2022 2:20 am
