Any experience with Eryone Matte PLA?
PaulB
(@paulb)
Has anyone tried the Eryone Matte PLA? DOes it need a hardened nozzle? I get great results with standard Eryone PLA, it's become my go to for cheap PLA from Amazon.
Wondered if I need to buy a new nozzle for it.
Thanks
Paul
Opublikowany : 22/06/2021 10:11 am
Steve Kohls
(@steve-kohls)
Any luck printing with it?
Hi Paul,
Any luck printing with the Eryone Matte PLA? I have some Matte Olive Green that I'm getting ready to print with and was wondering what settings you used.
Thanks,
Steve
Opublikowany : 17/08/2021 1:26 am
PaulB
(@paulb)
Works grear
Yes, I printed the eryone matte PLA on the default PLA profile and it printed fine, looks really good.
Opublikowany : 17/08/2021 8:42 am
PaulB
(@paulb)
0.6mm
I just remembered, I did use a 0.6mm nozzle, but I’m sure it would also be good on the standard. I have started to use a 0.6mm a lot as it’s much faster and the results are still very good.
Opublikowany : 17/08/2021 8:44 am
Nozzle
I used the generic PLA and a 0.4 nozzle.
Opublikowany : 17/08/2021 10:37 am
Steve Kohls
(@steve-kohls)
My results – more flow, less speed
So I used the generic PLA profile with my 0.4 nozzle. I did have some under-extrusion, both on the first layer and subsequent layers. I played with the flow rate and the print speed while printing and had some luck with 110% flow rate, and 90% speed. In the end, I'm not sure these would be the final parameters to use, but it did well enough on the print that I'm happy with it.
Opublikowany : 21/08/2021 7:27 pm
Eryone
Glad you found a solution.  Happy Printing.
Posted by: @steve-kohls
Opublikowany : 22/08/2021 12:22 am
